  3. generating multiple block placements
  • Views 15292
cadvin
cadvin over 12 years ago
Is there a skill that could possible generate multiple block placement with just one run?
    What do you mean by "block placements"? What tool are you using? What version? Please read the forum guidelines because vague questions will only result in vague answers, I'm afraid (or quite likely, no answers...)
  • cadvin
    Sorry for that. Im currently using virtuoso 6.1.5. Currently this version has automatic placement for analog blocks but could only create only one placement per block. What I'm looking for is something that could generate multiple layout placements for one schematic design.
    Hope this is clear already.
    Thanks..
    There is a multiple placement feature that is in engineering at the moment (it's under an early adopter license). So you would need to talk to your account team to see if there is a possibility that you could participate in early access partnership on this.
    Kind Regards,
