  3. how to tell the pin from the rect
  • Views 15665
acom
acom over 12 years ago
Hi  all,
i would like to slelect the pins in virtuoso layout and did some operation about them.
But i didn't know how to  identify whether i haven chose pins or other objects in layout.
i have tired to do like below,
if(pinn~>objType=="rect" then
operationA
else
operationB
);identify whether i had choosen the pins.if so, run operation A;if not, run operation B.
 But i found that there is a bug.For a rect drawn by metal, its property is the same.
metalrect~>objType="rect".
do you have any idea for me to  fix the bug?
    First of all, pins don't have to be rectangular - they can be any shape. What makes a pin a pin is that there is a figure (a shape or an instance) with the "pin" attribute. So if you do:
    if(pinn~>pin then ...
