  3. Change colors for rules in IC61 Cadence
  • Views 14835
hth83
hth83 over 12 years ago
Hi All,
   I am using IC61 Cadence. I want to change colors rules(layer) to look better. but i don't know how to change.Please help me.
thanks,
hth83
  • skillUser
    skillUser over 12 years ago
    If I've understood correctly you want to change the colour of layers in either a layout or schematic for better viewability.
    This is done through the file display.drf which usually resides in the working directory, or possibly in the library directory.
    This file can be modified using a text editor, or using the Display Resource Editor tool (Tools -> Display Resource Manager
    from the menus) .
    If you are colour blind then you may wish to look at this article.
    Hopefully this will help to answer your question?
    Lawrence,.
