  3. The edge is hilighted when the cursor is close to, how to...
  • Views 15382
The edge is hilighted when the cursor is close to, how to use skill to achieve it.
Evoli
Evoli over 12 years ago
Hi ALL,
         When the cursor is close to the edge of object, the edge is hilighted for ruler operation(bindkey: k) in Cadence615.
         How can I use skill procedure to achieve it?
         Thanks!
  • Evoli
    Could anybody help me??
    There is no public SKILL interface to do this. You could write code to highlight an edge yourself (using geCreateHilightSet/geAddHilightLine), but identifying the line is up to you. It's not a trivial amount of work...
    If you want something like this, you should contact customer support.
  • Evoli
    Thanks for the answer.
