  3. Moving over to 6.1.4
  • Views 15199
flintae32
flintae32 over 12 years ago
Hi Cadence Community
  I am having a bit of a problem transitioning existing layout designs from Cadence’s Virtuoso 5.10.4 to Virtuoso 6.1.4. Using the Conversion Tool Box feature CDB to OpenAccess Translator that is provided. The design transition over to 6.1.4 is relatively smooth, lvs checks are clean.  However, in running the Design Rule Check the following error message is trigger when running top level hierarchy cellview check which includes the seal ring and bondpads. All sub-cells DRC checks are clean.
[2044] offGridShapeErrors:  GRCE001: CHIPEDEG x and y dimensions must be an even number of grid points
I hope there is a fix or a work around for this challenge.
Any help or insight will be greatly appreciated
Johnny
    Which DRC tool are you using? Which foundry's PDK are you using?
    Is there a good reason to move to IC614? IC614 isn't supported any more - and hasn't been for some time, so it seems a bit odd to use such an old version when you could be using IC616 (or maybe IC615).
  • flintae32
    Hi Andrew Thanks for your quick response. I agree, we need to migrate to the latest version since we are a couple of revisions behind. Merry Christmas Johnny
