  3. Skill code to automatically map instances via name in layout...
  • Subscribers 150
  • Views 16257
Skill code to automatically map instances via name in layout xl
Deepon Saha
Deepon Saha over 12 years ago
Sometimes the layout instances don't map with the schematic (vxl clean) even if the lvs comes clean. I have to mannualy go to device correspondance & map them. Is there any skill code that can be used to map them when the layout xl fails to automatically map.
    Which version are you using?
  • Deepon Saha
    IC615 version.
    Deepon
     Deepon,
    VLS XL will do some mapping itself in this version, but a better approach might be to move to IC616 which has a Connectivity->Update->Binding menu which gives some more advanced ways to try to reach correspondence.
