  3. Adding library pathes
  • Replies 10
  • Subscribers 153
  • Views 27954
psill000
psill000 over 12 years ago
The envirnoment  creates a new cds.lib file when cadence virtuoso starts per session.
Is there a better way of adding additional library pathes than creating a procedure to append the cds.lib by printing out a text file to the cds.lib file?
 Example of current procedure:
procedure(addLibPath()
let(    (
    (addLibFile "./adLibs.txt")
    (mainLibFile "./cds.lib")
if(isFile(addLibFile) && isFile(mainLibFile) csh(strcat("cat " addLibFile " >> " mainLibFile)))
  • skillUser
    skillUser over 12 years ago
    a new cds.lib file is only created if one does not exist and you try to access a library (e.g. open the Library Manager).  You could open the cds.lib for writing in append mode (fileHandle = open("cds.lib" "a")) and write the new definitions (fprintf(fileHandle "define ....\n")) and then save it (close(fileHandle))...  I have not tried this but it should work (unless the cds.lib file is somehow locked?)  Have I understood what you are trying to do?
    Hope it helps!
    Lawrence.
    Lawrence,
    There's an easier solution. Use ddCreateLib - if you give this the name and path to an existing library, all it will do is add that entry into the cds.lib - no need to use file I/O functions.
  • skillUser
     Great!  I didn't know about that, but it makes sense that ddCreateLib behaves that way.
    Lawrence.
  • tyanata
    tyanata over 12 years ago
    If we have in cds.lib file INCLUDE statement and for example file try.lib is included, is there a way during the library creation to select if we want the new library definition to be written in cds.lib or in try.lib file?
    Best regards,
    tyanata
    This should (I think) do it:
    ddSetForcedLib("/path/to/includedcds.lib")
    ddCreateLib(...)
    ddSetForcedLib("")
    ddUpdateLibList()
    I would try to do this before you've opened any design though, because if designs are open which are no longer referenced from the "forced" cds.lib, you may get a popup...
  • MorrisDH
    MorrisDH over 4 years ago in reply to Andrew Beckett
    I tried this can got this a warning about using an illegal library name. I can add the same library through skill but ddCreateLib doesn't cooperate.
    Andrew Beckett over 4 years ago in reply to MorrisDH
    Please read the forum guidelines. You've posted on the end of an 8 year old thread, with no information about the version you're using, no details of the actual warning you got or how you were calling ddCreateLib. I'm not sure how you expect anyone to help you?
  • MorrisDH
    Sorry about all that - didn't notice the age of the thread. It was returned on a duckduckgo search and I jumped in with guns blazing without concern for anything. My apologies.
    My apologies also for the vagueness. And the bare minimum I did offer is stated incorrectly. Correction on my previous:  I can add the "illegally" named library through the GUI, not skill. It is the skill command that returns the warning.
    In my defense it was very late, I needed sleep, and the actual warning from the CIW is not much more informative than I was. Below is the input in the CIW and returned warning.
    ddCreateLib("/path/to/myLib")
    *WARNING* ddCreateLib: lib name '/path/to/myLib' is not a legal library name.
    Tool Version
    Program:        @(#)$CDS: virtuoso version 6.1.8-64b 04/27/2021 19:30 (cpgsrv11) $
    Sub version:        sub-version  IC6.1.8-64b.500.18  (64-bit addresses)
    As stated, the exact same library path can be added using the interface. I also cut and pasted the path into a terminal to make sure an 'ls' command on that path within a shell terminal works. Also verified that tech.db, cdsinfo.tag, etc existed.
    I can also manually edit the cds.lib with "DEFINE myLib /path/to/myLib" and that also works.
    Next I attempted the same command on two other libraries and got the same warning.
    That's because you've used the function incorrectly. The first argument is the library name not path. The second argument (which is optional) is the library path. Consequently it is objecting to there being a "/" in the library name, which is indeed illegal. To use it correctly (as is clear from the documentation), it would be:
    ddCreateLib("myLib" "/path/to/myLib")
  • MorrisDH
    Perfect!
    Yes, it is clear in the documentation. I looked at the documentation but I have a tendency to skip down to the examples. Shame on me.
