  3. New to skill, looking to do something simple, add text to...
  • Subscribers 150
  • Views 17060
New to skill, looking to do something simple, add text to a path
gstarr
gstarr over 12 years ago
I am new to skill coding and am trying to do something pretty simple but having some trouble and haven't been able to find something to help me out.  Basically I am trying to create a path and then add text to it for the path name.  I can generate the paths using the leCreatePath command but I can't find the right command and format for adding text to the path.  Ideally I would like the text to be attached to the path.  Any help would be greatly appriciated.
  • skillUser
    skillUser over 12 years ago
    You can create a label using the dbCreateLabel() function, and then attach it to the path database object using the leAttachFig() function.
      let( (pathObj label)
        pathObj = leCreatePath( ... )
        ;; when the path was created, create the label for it
        when(pathObj
          label   = dbCreateLabel( ... )
          ;; when the label is created, attach it to the path
          when(label
            leAttachFig(label pathObj)
          ); when the label was created
        ); when the path was created
      ); let
    Hopefully this is enough information to get this working for you?
    Best regards,
    Lawrence.
  • gstarr
    Do you have an example of the syntax for using the dbCreateLabel command?
  • skillUser
    You could search in support.cadence.com, or in the documentation. You should be able to find the following:
    dbCreateLabel(
    d_cellView
    tx_layer [ t_purpose ]
    l_point
    t_label
    t_just
    t_orient
    t_font
    x_height
    => d_label / nil
    Example dbCreateLabel(cv 4 1:1 "myLabel" "centerLeft" "R0" "roman" 2)
    Best regards,
    Lawrence.
  • gstarr
    I am up and running.  Thanks for the help !
