  3. Making SKILL manipulation of objects constraint aware
  • Views 14980
Yaosan Yeo
Yaosan Yeo over 12 years ago
I'm wondering if there's some kind of callback function I could call to make any manipulation I do on an object constraint aware. For example, if the symmetry constraint is set for two instances just so they are symmetrical along an axis. If I use non-interactive SKILL command to change one of the instances e.g. dbMoveFig(), the other objects will not move and it will break the constraint right away with warnings marker drawn on top of both instances.
Any way I can get around this problem without using functions like leHiMove()? Thanks!
    I don't know of a way to do this, so you should contact customer support - it probably needs an enhancement to make such a function available.
  • Yaosan Yeo
    Thanks for your input Andrew. I've filed a customer ticket for this enhancement request.
