  3. How to detect and remove dangling nets in schematic?
  • Views 18271
ffoo
ffoo over 12 years ago
Is there skill codes available to detect and remove dangling nets in schematic?
Thanks.
    I've never written anything to do this - maybe somebody else has. It probably depends on your definition of "dangling"... detecting a wire which isn't connected at all is easy enough, but it gets a little trickier (not impossible though) to detect wires that are only connected at one end. You'd probably have to use dbGetOverlaps to determine if there was something under the vertices of the wires.
