  3. hierarchy delete
  • Views 16163
hierarchy delete
NcfC
NcfC over 12 years ago
Hi, is there any skill code that would delete hierarchically all the cells/views (layout, schematic, symbols, etc) of a given circuit block in a library?
Thanks in advance.
  • skillUser
    skillUser over 12 years ago
    You will probably need to iterate over the objects yourself, but try getting the 'dd' object using ddGetObj() and then using ddDeleteObj() to remove it from disk.  I think this is the sort of thing that you are looking for?
    Lawrence.
  • NcfC
    OK. I'll try it. Thanks very much.
