  3. Is there a function to get first several elements of a list...
  • Views 19188
Is there a function to get first several elements of a list?
richardyuan
richardyuan over 12 years ago
I need to get part of a list. Is there a function in skill? It's better return a list.
I tried some coding, but failed:
a = list((0:0) (1:1) (2:2) (3:3) (4:2) (5:0))
b = nthcdr(3 a)
c = remove(b a)
As I suppose, c should be a list of ((0:0) (1:1) (2:2)). But actually c is equal to a.
What's wrong?
    You can do this destructively (which means it is quite efficient) using the following:
    rplacd(nthcdr(2 a) nil)
    a =>  ((0 0) (1 1) (2 2))
    If you wanted a non-destructive list range function, you could implement it like this:
    procedure(CCFlistRange(lst start end)
      let((tail)
        tail=copy(nthcdr(start lst))
        rplacd(nthcdr(end-start tail) nil)
        tail
    Whether this would be more efficient than doing something like:
      let(((count 0))
        setof(elem lst prog1(count>=start && count<=end count++))
    Would need some profiling and testing with various list sizes.
