  3. bindkey problem.
  • Views 16311
bindkey problem.
bsrin
bsrin over 12 years ago
Hi All,
I have some set of bindkeys for layers like (M1, M2...), but few of them are not working properly. To work that bindkey I have to press "Esc" button before pressing bindkey (let say <Key> 1)
when I check the definition of that bindkey (key 1)  in bindkey Editior window, I see some special command which I don't know under Enter function command column.
<Key>1               leSetEntryLayer(list("M1" "drawing"))                     drdEnabelPixelThreshold(!drdlsPixelThresholdEnabled())
  Can anybody tell me what is    drdEnablePixelThreshold(!drdlsPixelThresholdEnabled())     . And how to avoid it.
 Below is the code.
procedure( SMac(n)
               let( (a b)
              sprintf(a "<Key>%d" n)
              sprintf(b "leSetEntryLayer(list(\"M%d\" \"drawing\"))" n)
             hiSetBindkey("Layout" a b)
            ) ; let
) ; Smac
for(i 1 9 SMac(i))
    This is described in solution 11857664. The new bindkey for key 1 is documented in the Virtuoso Design Rule Driven Editing User Guide, in the DRD Advanced Features chapter, under the section DRD Smart Snapping. It describes using the "`" bindkey to freeze the halo, and then using the "1" bindkey to temporarily turn off smart snapping, whilst keeping the frozen halo.
    If you don't need that functionality, you could override the bindkey as described in the solution.
    Kind Regards,
  • bsrin
    Thanks Andrew .
     I also have same kind of problem. That is
    Shift<Key>3   - bindkey is not working.
    I have tried with may other ways to work with this key. But non of them work with only this "Shift<Key>3" bindkey.
    Is there a special reason that in IC6 version "Shift<Key>3 " is not working.
    Thanks In Advance,
    bsrin
    Hi bsrin,
    There are several other posts on similar topics. For example this one.
  • bsrin
    Thanks alot Andrew for your kind response.
     Yes , I found the solution in this community.
    bsrin.
