  3. How to write more efficient skill code for PCell?
  • Views 17168
richardyuan
richardyuan over 12 years ago
I wrote a PCell program for a MEMS project recently. The code imitates virtuoso automatic generated PCell program. It looks lengthy and run very slowly.
How can i make it more effective?
1. How to retrieve PCell parameters more simply. Here is my let paragraph, looks ugly:
    let((p1_d1 p1_r2 p1_r3 v1_r p1_leaf_style p1_leaf_l p1_leaf_w p1_leaf_hd
p1_notch_w p1_slot_angle p1_slot_ir p1_slot_or p1_slot p2_notch_angle
p2_notch_ir p2_notch_or p2_notch ang ang0 ang1 angi inita DPI x y i num
p1 p2 p3 p4 sides
pcInst  pcParameters pcParamProp pcLayer pcPurpose
) ;local parameters
(pcLib = (pcCellView~>lib))
;Retrieve pCell parameters
(pcParameters = ((pcCellView~>parameters)~>value))
(pcParamProp = car(exists(prop pcParameters
   ((prop~>name) == "P1_Visible")
(p1v = (pcParamProp~>value)) ;P1_Visible
   ((prop~>name) == "P2_Style")
(p2s = (pcParamProp~>value)) ;P2_Style
   ((prop~>name) == "P1_D1")
(p1_d1 = (pcParamProp~>value)) ;P1_D1
   ((prop~>name) == "P2_D1")
(p2_d1 = (pcParamProp~>value)) ;P2_D1
   ((prop~>name) == "P1_R2")
(p1_r2 = (pcParamProp~>value)) ;P1_R2
   ((prop~>name) == "P2_R2")
(p2_r2 = (pcParamProp~>value)) ;P2_R2
   ((prop~>name) == "P1_R3")
(p1_r3 = (pcParamProp~>value)) ;P1_R3
   ((prop~>name) == "P2_R3")
(p2_r3 = (pcParamProp~>value)) ;P2_R3
   ((prop~>name) == "V1_R")
(v1_r = (pcParamProp~>value)) ;V1_R
   ((prop~>name) == "V1_L")
(v1_l = (pcParamProp~>value)) ;V1_L
   ((prop~>name) == "V3_D")
(v3_d = (pcParamProp~>value)) ;V3_D
   ((prop~>name) == "V3_SP")
(v3_sp = (pcParamProp~>value)) ;V3_SP
   ((prop~>name) == "V3_EE")
(v3_ee = (pcParamProp~>value)) ;V3_EE
   ((prop~>name) == "P1_Leaf_Style")
(p1_leaf_style = (pcParamProp~>value)) ;P1_Leaf_Style
   ((prop~>name) == "P1_Leaf_L")
(p1_leaf_l = (pcParamProp~>value)) ;P1_Leaf_L
   ((prop~>name) == "P1_Leaf_W")
(p1_leaf_w = (pcParamProp~>value)) ;P1_Leaf_W
   ((prop~>name) == "P1_Leaf_HD")
(p1_leaf_hd = (pcParamProp~>value)) ;P1_Leaf_HD
   ((prop~>name) == "P1_Notch_W")
(p1_notch_w = (pcParamProp~>value)) ;P1_Notch_W
   ((prop~>name) == "P2_Notch_W")
(p2_notch_w = (pcParamProp~>value)) ;P2_Notch_W
2. How to fill shape A with array of circular shape B efficiently,
    make sure B is inside A and the distance of B edge to A edge should be larger than 3um?
    I tried to use dbCreateEllipse in multiple loops. And it took several minutes to get a final result, seems very inefficient.
    Quick answers:
    1. If you use pcDefinePCell() to define your pcell, it will take care of all the parameter definition and lookup for you (it will create the parameters on the parameters hierProp and it will look up the values). It's much cleaner.
    2. I'm not sure what kind of shape A is, but it's more efficient to create a mosaic for the array. Create your single circle as a cell (either a fixed cell or a pcell) and then use dbCreateSimpleMosaic or dbCreateParamSimpleMosaic to place the array of these. If you are drawing many circles, this will be much more efficient (assuming that they are evenly spaced). Hard to give much more advice without seeing what you're doing and seeing an example that is slow.
  • richardyuan
    For the second question, I'll create a new post.
    I now think It's no need to use lots of "(pcCellView~>parameters)~>value)"  and "car(exists(...))" in the pCell definition.
    For more efficient coding, can you give any advice on the following?
    pcDefinePCell(list(ddGetObj("TTA") "ycRotate" "layout")
        (   (p2_r1 float 300.0)
    (p2_gapl float 280.0)
    (p2_gapa float 70.0)
    (p2_gapb float 25.0)
    (SETS int 20)
        let((i x0 div_angle p2_base p2_rect p2_gap yctView
    ) ;local parameters
    (pcPurpose = "drawing")
    div_angle = 360.0/SETS
    (p2_base = dbCreateEllipse(pcCellView
    list(4 pcPurpose)
    list(((-p2_r1):(-p2_r1)) (p2_r1:p2_r1))
    (p2_rect = dbCreateRect(pcCellView
    list(64 pcPurpose)
    list((p2_gapl:(-p2_gapb)) ((p2_gapl + 2*p2_gapa):p2_gapb))
    yctView = dbOpenCellViewByType(" TTA " "YCTemp" "layout" "maskLayout" "s")
    p2_gap = dbCopyFig(p2_rect yctView)
    for(i 2 SETS
    dbTransformCellView(yctView 1 div_angle)
    dbCopyFig(p2_gap pcCellView)
    ); for i
    dbClose(yctView)
        ); let
    ); Pcell define
    Nothing really there that should be slow. You don't need these lines in the code:
    Because they aren't used, but that won't slow it down really.
