  3. Instance True BBox value
  • Subscribers 153
  • Views 17921
psill000
psill000 over 12 years ago
Just try to keep the script simple.
Is there a variable that will give the TrueBBox value of an instance in layiout or will I have to look in the cellview and get the prBoundary bbox??
    What do you mean by TrueBBox? Are you talking about what the useTrueBBox env var does, which is to show the bounding box as the instance layer (if present) or the actual bounding box otherwise (also the instanceDrawingMode env var has an effect here - you can choose to display using the prBoundary instead of the instance layer).
    The actual bounding box is given by instId~>bBox, but any bounding box based on a particular layer or object would require looking inside the object. If it's the prBoundary you want, that's easy - you could just do:
    inst~>master~>prBoundary~>bBox || inst~>bBox
    (this is for IC61, since prBoundary is a separate object, and so no searching of layers is needed). This expression will give you the box for the prBoundary if it is there, or falls back to the overall bounding box if not.
  • khaim
    khaim over 5 years ago in reply to Andrew Beckett
    transform needs be applied
    Andrew Beckett over 5 years ago in reply to khaim
    What does this mean? You posted a four word statement onto the end of an eight year old thread. Please read the forum guidelines before posting...
  • khaim
    khaim over 4 years ago in reply to Andrew Beckett
    dbTransformBBox(instID~>master~>prBoundary~>bBox dbGetInstTransform(instID))
    i mean he wants the bbox of the instance, so he should do as above
