  3. [Assura 414] Fail to load context file
  • Views 15871
Duy Hien
Duy Hien over 12 years ago
Hi everyone,
I have a question about Assura 414. My systems: Cadence IC615 Assura 414. When I open a layout, there is a warning:
*WARNING* Failed to load context file <install_dir>/ASSURA412/bin/32bit/etc/context/6.1.5/sna.cxt'
I did not find that file or that link in installed directory. I wonder it may cause error or not? and where can I find the file which tries to load sna.cxt file?
Please give me an advice.
Thank you so much.
    There's a solution on this - it explains that the warning is benign (the file is not supposed to exist any more) and that it will be removed in a later release. In fact I don't see it using these versions:
    UNIX> assura -W
    sub-version 4.1_USR4_HF3
    UNIX> virtuoso -W
    sub-version  IC6.1.5.500.17
  • Duy Hien
    Thank you so much for your help.
    I am sorry, I cannot access the link. Can you post the information in this site, please?
    All it tells you is that the features of Substrate Noise Analysis is now part of QRC and no longer supported as part of Assura, and to ignore the warning message.
  • Duy Hien
    Yes, thank you so much!
