  3. Skill++ - create another class that is composed of two instances...
  • Subscribers 150
  • Views 1096
Skill++ - create another class that is composed of two instances from another class
rflayout
rflayout over 12 years ago
I've created a class that is supposed to represent a two-dimensional point. It is defined here:
 defclass( gf_2dPoint
   () ;superclass
      (x
         @initarg x
         @reader getX
         @writer setX
      (y
         @initarg y
         @reader getY
         @writer setY
) ; defclass
Then in my main procedure I instantiate two points like so:
   gf_Pt1 = makeInstance('gf_2dPoint ?x 0 ?y 3)
   gf_Pt2 = makeInstance('gf_2dPoint ?x 2 ?y 5)
I wanted to create another class, maybe called gf_line, whereby a gf_line instance could be created with the makeInstance and passing to gf_2dPoint objects.
Thanks for any insights.
By the way, I may just use a simpler procedure solution, but was a bit curious.
-Gary
    Gary,
    I think you've answered your own question. Probably you'd just use:
    defclass(gf_line ()
        (pt1 @initarg pt1 @reader getPt1 @writer setPt1)
        (pt2 @initarg pt2 @reader getPt2 @writer setPt2)
    gf_l1=makeInstance('gf_line ?pt1 gf_Pt1 ?pt2 gf_Pt2)
    It wouldn't make much sense to use inheritance here - since a line is not a special type of a point.
  • rflayout
    Seems to work. I'll need to read up on defining methods, etc.
    Thanks.
