  3. Help me! Skill Experts!
  • Subscribers 150
  • Views 15993
sshinh
sshinh over 12 years ago
Hi, All!
I'm basic layout engineer.
Today, I made a skill script for layout metal layer on & off.
But, it's not run.
I don't know the reason.
Please, help me!
p.s> I use cadence IC6.1.5
procedure(view()
 leSetLayerVisible(list(\"M1\" \"drawing\") t)
 leSetLayerVisible(list(\"M2\" \"drawing\") t)
 hiRedraw()
) ;procedure
call bindkey setting
hiSetBindKeys("Layout" list(
list("Ctrl<Key>1"   "view()")
CIW error message
 *Error* view : too few arguments (at least 1 expected, 0 given) - nil
  • ebecheto
    ebecheto over 12 years ago
     pp view
    pp : view is a read protected function and cannot be pretty printed
    nil
    chose another name for your function !
    In general we would recommend that any customer-written global functions use a prefix, ideally beginning with an uppercase letter (since uppercase prefixes are not used by Cadence) - to avoid clashing with other similar functions.
    As has been mentioned, view() is a Cadence-provided function and is write protected, so your function definition would fail.
  • sshinh
     Andrew!!
     Thank you for your advice.
     But it's not run. (Modify file name : view -> View)
    *Error* eval" unbound variable - \"M1\"
     What's mean?
     Skill function is wrong?
    That's because you have escaped the quotation marks and shouldn't have because they are not embedded inside strings. So it should be:
    procedure(View()
     leSetLayerVisible(list("M1" "drawing") t)
     leSetLayerVisible(list("M2" "drawing") t)
     hiRedraw()
    ) ;procedure
  • sshinh
     Thank you so much! Andrew!
     It's run.
     Seungha
