  3. Schematic cdf value not displaying correctly
  • Views 15723
psill000
psill000 over 12 years ago
I have a script that sets the cdf value of a schematic symbol but it does not display the value correctly in the schematic cellview. When I look at the value from the property menu the values are correct. I have to toggle the variable on the property menu nil and back to t then values will display in the cellview correctly.
 Is there a callback the property menu does when you hit apply/OK that I need to add the script. Or am I missing something in the script to update the schematic cellview.
Some different examples I am trying:
procedure(stdLib_getPcellCdf(obj var)
let(    (cdfVal)
foreach(cdf cdfGetInstCDF(obj)~>parameters
        if(equal(var cdf~>name) cdfVal = cdf))
cdfVal
); end of let
); end of stdLib_getPcellCdf
procedure(stdLib_setPcellCdf(obj var val) stdLib_getPcellCdf(obj var)~>value = val )
procedure(chngSymVal(cv)
foreach(a cv~>instances
cd=cdfGetInstCDF(a)
foreach(param cd~>parameters
if(equal("multidesign" param~>name) then param~>value=t hiFlush() )
schCheck(cv)
dbSave(cv)
  • skillUser
    skillUser over 12 years ago
    Hi Paul,
    Unless I am mistaken, the CDF parameter in question has a callback associated with it?  When an instance CDF parameter is changed using SKILL, the callback is not called as it would be when changing the value from the GUI.  Take a look at solution 11018344.
    Hope this helps.
    Lawrence.
