  3. Automatically modify menu items in schematic editor on ...
  • Subscribers 150
  • Views 16985
Automatically modify menu items in schematic editor on startup
johancsi
johancsi over 12 years ago
I am trying to redefine bind keys and menu items for some functions within the schematic editor as well as add another pulldown menu to the banner menu.  I have working code that does this if I start the schemtic editor first by hand, and it works well.  When I open up an additional schematic window, the bind keys and menu callback function overrides are all there, but the new pulldown menu is gone.  I don't want to have to run the initialization script by hand everytime I open a new shematic window.
The code to re-assign the callback functions and new pulldown menu don't work unless a schematic window is opened first.  I therfore open up a dummy schematic window, run my setup, and then close the dummy schematic window.  I think this is kind of a kludge, and it doesn't keep my pulldown menu anyway.  I also don't want to modify the menu files.  Is there anyway to run a skill script every time a schematic editor starts up?  I am running the IC615 version.  Below is the initialization code snippet that I am using.  I load this and run it within the .cdsinit in my home directory.
svID=deNewCellView("sandbox" "temp1" "schematic" "schematic" nil)
sv1ID=geGetWindowCellView(svID)
adCreateLayoutMenuItem = hiCreateMenuItem(?name 'adCreateLayoutMenuItem ?itemText "Create Layout" ?callback "adCreateLayout")
hiCreateMenu( 'adToolsPulldown "Tools" list( adCreateLayoutMenuItem ) )
hiInsertBannerMenu( hiGetCurrentWindow() 'adToolsPulldown 5 )
hiSetBindKey("Schematics" "None<Key>i" "adHiCreateInst( )")
hiSetBindKey("Schematics" "None<Key>w" "adHiCreateWire( )")
hiSetBindKey("Schematics" "None<Key>p" "adHiCreatePin( )")
hiSetMenuItemCallback(schAddMenu 'InstItem "adHiCreateInst()")
hiSetMenuItemCallback(schAddMenu 'WireItem "adHiCreateWire()")
hiSetMenuItemCallback(schAddMenu 'PinItem "adHiCreatePin()")
dbClose(sv1ID)
  • Li Ting
    Li Ting over 12 years ago
    The proper way to customize the setup of an editor is to use the deRegUserTriggers function. This function allows you to register three different functions to handle your customization needs for a specific view type.
    Please refer to the user documentation on how to use this function.
  • skillUser
    skillUser over 12 years ago
    Hi Johan,
    Another way to modify the tools' menus is to use the menus file approach, in this case there will be a schematic.menus file in the installation which is loaded by default.  You can have a directory named "menus" in your current or home directory that contains your own "schematic.menus" file; this can load the original and then modify or add to the structure.
    Your schematic.menus file could contain something like the following:
    ;; load the original Schematic menus
    load(prependInstallPath("/etc/tools/menus/schematic.menus"))
     Take a look at the structure in the original file and you can see how to modify or build new menu items and menus...
    I hope this helps,
    Lawrence.
