  3. Cant alias this bindkey command
  • Views 15034
howardhaoracle
howardhaoracle over 12 years ago
Hi..
Can you please tell me what is wrong with this bindkey setting:
 hiSetBindKey("Layout" "Shift<Key>n"   leSetFormSnapMode("orthogonal"))
at the CIW prompt ,it returns t
But when I tried to use this bindkey, I got the error  *Error* toplevel: undefined variable - orthogonal
However, if I change the synctax from orthogonal to anyAngle, it works fine.. (Why??)
Thank you very much for your help
Howard
  • skillUser
    skillUser over 12 years ago
    Hi Howard,
    You seem to be missing some quotes and escapes for embedded quotes, though I'm not sure how the "anyAngle" version can work...
    Here is what it could look like when corrected:
    hiSetBindKey("Layout" "Shift<Key>n"   "leSetFormSnapMode(\"orthogonal\")")
    Hopefully this helps you.
    Lawrence.
  • howardhaoracle
    Hi Lawrence..
    You are amazing.. It works!!!!
    Thank you very much for your prompt help
    Howard
