  3. SKILL++ private functions
  • Subscribers 150
  • Views 15793
acook
acook over 12 years ago
I've read the Skill manual as well as done some poking about but I still am somewhat unclear on how to delare a private function for a class method.
 For instance, I have a class "Example"
 defclass( Example () () )
 Now I give it a method
defmethod( Fun (( obj Example))    .... )
How can I define a procedure that only "Fun" can access.
Secondly, how do I define procedures that only methods of "Example" can access?
  • acook
    In addition is it possible to give a set of procedures their own private procedure
     procedure( fun1() private1() )
      procedure( fun2() private1() )
    procedure( private1() println("HI") )
    Where private1 is only visible to fun1 and fun2
    For the second post, you can do this:
    let(()
      procedure(private1()
        println("This is private")
      globalProc(fun1() private1())
      globalProc(fun2() private1())
    Put this in a file called "mycode.ils" (the .ils suffix is important). This will then use lexical scoping. The globalProc tells SKILL that the function should be visible in the global scope, rather than only in the lexical scope. globalProc is available from IC615 onwards. If using IC614 or before (or IC5141 or before), you can achieve the same end by doing:
    let(()
      procedure(localfun1() private1())
      procedure(localfun2() private1())
      ; functions can be retrieve as variables in SKILL++, so assign
      ; to non-local variable names to make the functions available
      ; in the global scope
      fun1=localfun1
      fun2=localfun2
    As for your first post, I'm not entirely sure what you mean. But it's probably this:
    let(()
      defmethod(Fun ((obj Example))
        private1()
    defmethod inside a let does not make it local - that's because the generic function is global, essentially. But it will honour the lexical scoping - so you can call a function in the same lexical scope.
    Kind Regards,
