  3. SKILL++ variable in form callback
  • Views 15489
acook
acook over 12 years ago
Another SKILL++ question!
 I have a procedure that has a class instances as well as a form declaration. I would like to have the form callback use a class instance method. My current solution is to declare the class instance using "inSkill" so that it is global to the form. Is there a way to keep it private?
procedure( makeForm() <-----this procedure is in a SKILL++ .ils file
 obj = makeInstance( 'MyClass)
   b_run =hiCreateButton(
            ?name 'run_button
            ?buttonText "Run"
            ?callback Run(obj)  ; <--- Option 1 Evaluates immediatly
            ?callback strcat("Run(" myObjName ")"); Option 2 requires myObjName, a string that refers to an object instances, as well as whatever the object instance is to be global
Option 1 doesn't work at all but is kinda what I'm looking for, where I just want Run(obj) to happen when the button is pressed. obj is kept private
Option 2 is what I am currently doing, in another area I run the makeInstance "inSkill".
    In IC616 you can have callbacks be a function object. So you could make the callback ?callback lambda((fieldName form) Run(obj)). Then it would be lexically scoped to the place where the button was created.
    Prior to IC616, the callbacks have to be strings (for fields), and will be executed in the global scope. What you could however do is store the object as a property on the form (so having built the form, you could do myForm->myObj=obj - and then you could access that from within the callback function). The callback function would in that class have to be visible - because it's just evaluated (in SKILL, not SKILL++) using evalstring().
