  3. Strange Issues in spiceIn
  • Views 19910
zczc999
zczc999 over 12 years ago
Hi, all
 I have a problem during spiceIn.  I want to import hspice to schematic, but I get an error of:
Inst: RXM0
Found net 'AIN'.
Found net 'AINOUT'.
Master Cell: 'resistor'.
Did not find 'silterraC13.resistor:symbol'.
ERROR (SPICEIN-24): Spice In did not find the symbol view of the master cell 'resistor' of the instance
'RXM0' in the subcircuit 'ANALOGIO60_33'. Specify the reference library that has the symbol
view of the master cell, or use device-mapping to map 'resistor' to a different
Actually, in the spice file, the model of RXM0 is not resistor but "sbpp". And sbpp does exist in the reference library.
.subckt ANALOGIO60_33 AIN AINOUT AVDD33 AVSS33 VDD VSS VSSIO VREF DIFREF
DXDM16 AVSS33 AIN pnt AREA=75.717P PJ=112.208528U
DXDM17 AIN AVDD33 pnt AREA=75.717P PJ=112.208528U
DXDM14 AINOUT AVDD33 pnt M=4 AREA=75.717P PJ=112.208528U
DXDM15 AVSS33 AINOUT pnt M=4 AREA=75.717P PJ=112.208528U
MM6 AVSS33 AVDD33 AVSS33 AVSS33 nm_33 W=324U L=8U M=1
RXM0 AIN AINOUT sbpp w=6U l=6U
.ends
 When I mapped "resistor" to "sbpp" in device mapping file, all the resistors in the spice file are mapped to sbpp.
 The cadence version is IC6.1.5, any one knows how to fix this ?
Thank you!
  • Quek
    Quek over 12 years ago
    Hi zczc999
    Just to gentle reminder that non-SKILL related questions should be posted to the "Custom IC Design" forum.
    If not mapping is provided, spiceIn will simply look for the generic cellname "resistor". This is the expected behaviour. The following mapping should be able to resolve the problem:
    devSelect := resistor sbpp
    propMatch := subtype sbpp
    Best regards
    Quek
  • zczc99
    zczc99 over 12 years ago
    sorry for posting it here. But the question is that in the hspice file the model of RMX0 is not "resistor", but it is "sbpp", why spicein take "resistor" as the cell model.
    Thank you!
    If you don't specify a devMap, it doesn't know what to do with it and so uses the default behaviour - which is to assume that an instance beginning with R is a resistor. With a devMap, you can get different models to map to different components - there's no guarantee that the model name will map to the cellName in a pdk - which is why there's a mapping capability.
  • zczc99
    Dear Andrew,
      In the netlist, there are 2 different types of resistors: sbpp and snp. So the device mapping file I am using is:
     devSelect := resistor snp
            propMatch := subtype snp
    But  there are still problems after spicein.
    the resistor defination in netlist is :
     RXM2_I59_I1_I0 I1_I0_NET0126 I59_I1_I0_NET069 sbpp w=1U l=26U
    in spicein.log,
     Inst: RXM2_I59_I1_I0
            Created net 'I1_I0_NET0126'.
            Created net 'I59_I1_I0_NET069'.
            Master Cell 'resistor' mapped to 'snp'.
            Did not find 'analogLib.snp:symbol'.
            Master Cellview: 'silterraC13.snp:symbol' found.
            Created instance 'RXM2_I59_I1_I0'.
            Created connection between net 'I1_I0_NET0126' and term 'PLUS'.
            Created connection between net 'I59_I1_I0_NET069' and term 'MINUS'.
            Created propName='model'; propType='string'; propVal='resistor'.
            Created propName='calculatedparam'; propType='string'; propVal='Length'.
            Created propName='r'; propType='string'; propVal='sbpp'.
            Created propName='segW'; propType='string'; propVal='1e-06'.
            Created propName='segL'; propType='string'; propVal='2.6e-05'.
     It seems that spicein didn't treat "sbpp" as a subtype, but the resistance value. So that only the first mapping commands "devSelect := resistor snp     propMatch := subtype snp " is effective, and all the "sbpp" and "snp"resistors are mapped to "snp",  also the resistance value is set to a string "sbpp" or "snp".   How to map correctly in tis case?
    Thank you!
