  3. Regarding via generation through key
  • Views 15516
rajs
rajs over 12 years ago
Hi ,
I wrote a skill program which generate via in the cursor point on layout window. My requirement is to have this via attached to cursor untill i clicked on layout window. I mean it should not place in layout window but to generate and move along with cursor untill the next click.
Here is the part of code i pasted
dbCreateVia(cv viaid1 hiGetPoint(wi) "R0" viaparams)
Kindly let me know.
    You don't really have complete freedom for rubberbanding with any of the enterFunction functions (e.g. enterPoint), so there's not really a way to do this - other than really using leHiCreateVia() - and calling hiRegTimer() beforehand to trigger a function to fill in the form after it has appeared. Probably best to contact customer support over your requirements.
  • dmay
    dmay over 12 years ago
    I think you must use hiRegTimer to set the via name, but there is some relatively new functionality that lets you control parameter settings:
    viaRegisterPreViaEngineCallback(“myPreViaEngineCB”)
    Example:
    procedure(myPreViaEngineCB(veContext)
       printf("veContext = ") println(veContext)
       printf("veContext~>viaModel = ") println(veContext~>viaModel)
       printf("veContext~>viaModel~>?? = ") println(veContext~>viaModel~>??)
    Your code could do this:
    viaForm=leGetTechFormList(techGetTechFile(geGetEditCellView()))->viaForm
    viaForm->viaSingleModeScrollView->viaDefName->value="MYVIANAME"
    leHiCreateVia()
    Then update the preVia trigger to manipulate parameter information.
    Derek
    Thanks Derek - I think those functions had passed me by, so I learned something!
  • dmay
    Working with customer service to get a needed feature sometimes gives us customers the inside scoop when those new features are implemented. ;-)
    Derek
