  3. Re-directing text output to a text window other than the...
  • Subscribers 150
  • Views 17597
Re-directing text output to a text window other than the CIW
johancsi
johancsi over 12 years ago
I would like to open up a text window, and re-direct text output to that window.  The only thing that I can seem to find is to re-direct text output to a file by opening up a port. I have successfully created and displayed a new text window, but anything I try when printing text, always goes to the CIW.  Below is the code that I am using to create and display the new text window.
twID=hiCreateWindow('default "text" "my app")
hiDisplayWindow(twID)
print("Cell checked with no errors or warnings!!!\n")
Thanks for any help
 Tracy
    Tracy,
    Why wouldn't you use:
    port=outfile("./myout.txt")
    fprintf(port "Cell checked with no errors or warnings!\n")
    rather than printf? If you want the option to print to the CIW, you could always do port=stdout or port=poport and continue to use fprintf.
    It is possible to alter the poport variable to another file, but that has to be done with caution. Or you could use hiStartLog() and hiEndLog() to temporarily create a duplicate copy of part of the CDS.log to another file.
  • johancsi
    Thanks for the response.  I was asking about sending text to a pop up text window, not a file, and I don't want it to go to the CIW.  Right now, anything I print with print, println and printf, goes to the CIW.  Isn't there a way to direct text output to a window ID or something like that?  I can create a text window as I have shown in my example.  There must be some way to actually send text to it.  All I want is to pop up a window, and print a bunch of progress and status while a particular procedure is executing.  The user would then be able to close the window once they look at what was printed in it.
    Tracy
    Tracy,
    So you want hiTextDisplayString (I think), as in this post.
    Kind Regards,
  • johancsi
    Thank you Andrew.  That worked perfectly.
    Tracy
