  3. Error in storing output data into file
  • Views 14893
indra0804
indra0804 over 12 years ago
Hi experts,
I am new to cadence ocean scripting. I need to store the data of output wave that is generated, into a file. I am able to print the output value at a certain instant say the max value of the output wave using the following code.
V=ymax(v("/V" ?result "tran-tran"))
fprintf(of "%6.3e \n" V)
This code works fine and gives the correct max value.
But, now I want to get data about the entire output wave.
I tried by using the following code fragment for that.
V=v("/V" ?result "tran-tran")
But, this does not work as I expected it to be and all that I get as o/p is something like "srrWave:0x16832018"
Please suggest how I can proceed. I want to get the entire data stored into file.
Also, if there is a way by which I can store the o/p result at periodic instants say 'every 10ns' or something like that, that would be nice too.
Indra
    Indra,
    Use ocnPrint for this. For example:
    ocnPrint(V ?output of ?from startTime ?to endTime ?step 10n)
    There are other arguments for ocnPrint that might help - see the documentation for more details.
  • indra0804
    Thanx andrew, it helped.
