  3. Skill code to change layout pin direction to match schematic...
  • Views 17346
Skill code to change layout pin direction to match schematic direction.
Michael L
Michael L over 12 years ago
Can anyone share with me a skill program that will change layout pin directions to match the schematic pin directions?  Pins made by the generate pins from labels function all come in with the direction inputoutput, and I would like a skill program that changes them to match the schematic.
Thank you
    How about this:
    procedure(CCFsetTermDirections(@key (cvId geGetEditCellView()) (fromView "schematic"))
      let((fromCvId dirTable)
        fromCvId=dbOpenCellViewByType(cvId~>libName cvId~>cellName fromView)
        dirTable=makeTable('directions "inputOutput")
        ; record the direction for each expanded schematic terminal
        foreach(term fromCvId~>terminals
          foreach(termName dbProduceMemName(term~>name)
            dirTable[termName]=term~>direction
        ; and now set the layout terminals to match the schematic
        foreach(term cvId~>terminals
          term~>direction=dirTable[term~>name]
        t
    Open the layout view, and then run CCFsetTermDirections(). Note that the above is completely untested - I just typed it in. So it may need tweaking...
  • Michael L
    For those that are interested in the above code, there is a single typo.  "dbProductMemName" should be "dbProduceMemName".  Otherwise, the code works perfectly.  Thanks a ton Andrew.
    Thanks Michael - I edited the post and fixed the typo.
