  3. Including png files in the Application form
  • Views 16602
gharish
gharish over 12 years ago
Hai,
I want to include png files in the app form. Please help me. I have a requirement that if i select the picture its callback is executed.
    This could be a png (I picked a GIF, because there's one in the IC installation; there are png files too, but I thought I'd pick the Cadence logo):
    but=hiCreateButton(?name 'cadenceLogo ?callback "printf(\"I Love SKILL\n\")"
      ?buttonIcon list(cdsGetInstPath("share/cdssetup/dfII/publisher/html/cadence_logo2.gif") 100 40))
    hiCreateAppForm(?formTitle "Images on Forms" ?name 'CCFform ?fields list(list(but 0:0 110:50)))
    hiDisplayForm(CCFform)
  • gharish
     Thanks Dear,
    Now I have a set of pictures, I would like to include all these png files in my form. Now I have a requirement that at a time one picture should be visible to me. if i press next another picture should be visible, and each picture will have separate call backs. So please help me regarding this.
    Not quite sure why I ended up writing this complete example rather than just giving you some pointers, but maybe it will give others a recipe to start from...
    /* abExampleIconNextPrev.il
    Author     A.D.Beckett
    Language   SKILL
    Date       Feb 28, 2014
    Modified
    By
    An example showing how to implement a form with an icon
    button which shows one of a set of pictures, and has next
    and previous buttons to move back and forward through the
    list. Each picture has a corresponding callback function.
    See the details in the code - it's an example, so adapt to
    suit your needs.
    Call abExampleIconNextPrev() to create and display the
    form.
    SCCS Info: @(#) abExampleIconNextPrev.il 02/28/14.09:38:06 1.1
    *           abCreateExampleIconNextPrevForm(listOfPictures)           *
    *  Create the example form. This gets passed a list of lists, where   *
    * each sublist is the name of a file (assumed to be in the 48x48 dir) *
    *      the width and height of the image, and a callback string.      *
    procedure(abCreateExampleIconNextPrevForm(listOfPictures)
        let((next previous picture thisPicture)
            next=hiCreateButton(
                ?name 'next
                ?buttonIcon list(cdsGetInstPath("share/cdssetup/icons/16x16/arrow-right.png") 16 16)
                ?callback "abExampleIconNextCB(hiGetCurrentForm())"
            previous=hiCreateButton(
                ?name 'previous
                ?buttonIcon list(cdsGetInstPath("share/cdssetup/icons/16x16/arrow-left.png") 16 16)
                ?callback "abExampleIconPreviousCB(hiGetCurrentForm())"
            thisPicture=car(listOfPictures)
            picture=hiCreateButton(
                ?name 'picture
                ?buttonIcon list(cdsGetInstPath(strcat("share/cdssetup/icons/48x48/" car(thisPicture)))
                    cadr(thisPicture) caddr(thisPicture))
                ?callback "abExampleIconPictureCB(hiGetCurrentForm())"
            hiCreateAppForm(
                ?formTitle "Next Previous Example"
                ?name 'abExampleIconNextPrevForm
                ?fields
                    list(
                        list(previous 20:20 20:20)
                        list(picture 60:0 60:60)
                        list(next 140:20 20:20)
            ; Store the info on the form - the list of pictures and the currently
            ; displayed picture
            abExampleIconNextPrevForm->listOfPictures=listOfPictures
            abExampleIconNextPrevForm->thisPicture=thisPicture
    *                       abExampleIconNextCB(form)                        *
    * When the next button is pressed, update the button icon to the current *
    *        picture, and update the thisPicture property on the form        *
    procedure(abExampleIconNextCB(form)
        let((remainder thisPicture)
            remainder=memq(form->thisPicture form->listOfPictures)
            when(thisPicture=cadr(remainder)
                hiSetButtonIcon(form->picture
                form->thisPicture=thisPicture
    *                 abExampleIconPreviousCB(form)                  *
    * Similar to abExampleIconNextCB, but shows the previous picture *
    procedure(abExampleIconPreviousCB(form)
        let((thisPicture)
            thisPicture=car(form->listOfPictures)
            exists(picInfo form->listOfPictures
                eq(form->thisPicture picInfo) || (thisPicture=picInfo) && nil
            unless(eq(thisPicture form->thisPicture)
    *                  abExampleIconPictureCB(form)                  *
    * A generic callback function for the main picture button. This  *
    * retrieves the callback function (the 4th entry in the sublist) *
    *        and evaluates it with errset to trap any errors.        *
    procedure(abExampleIconPictureCB(form)
        when(form->thisPicture
            errsetstring(cadddr(form->thisPicture) t)
    *                   abExampleIconNextPrev()                    *
    *            The main function to display the form.            *
    procedure(abExampleIconNextPrev()
        let((listOfPictures)
            listOfPictures=
                    ("plot-waveform.png" 48 48 "MyPlotWaveform()")
                    ("output-setup.png" 48 48 "MyOutputSetup()")
                    ("delete-alt-1.png" 48 48 "MyDelete()")
                    ("variable-edit.png" 48 48 "MyVariableEdit()")
        hiDisplayForm(abCreateExampleIconNextPrevForm(listOfPictures))
    ; Example callback functions for each picture. None are
    ; terribly exciting...
    procedure(MyPlotWaveform()
        printf("Plotting a waveform\n")
    procedure(MyOutputSetup()
        printf("Output Setup pushed\n")
    procedure(MyDelete()
        printf("Delete the lot\n")
    procedure(MyVariableEdit()
        printf("Variable Edit engaged\n")
