  3. finding instances from selected objects
  • Subscribers 150
  • Views 18199
gharish
gharish over 12 years ago
I have a requirement that i have selected some objects. I want to filter instances only from the selected set of objects.
    setof(obj geGetSelSet() obj~>objType=="inst")
  • tweeks
    tweeks over 12 years ago
    You can also filter for male instances like this:
    setof(obj geGetSelSet() heIsInstObject(obj))
    heIsInstObject is also a private function. It's part of the hierarchy editor functionality, so do not use it in your code as it may be changed or removed without notice.
    The method I gave earlier should work fine. If you want to distinguish those which are not pins, also check the purpose attribute, so do:
    setof(obj geGetSelSet() obj~>objType=="inst" && obj~>purpose=="cell")
  • tweeks
    Ah, I was wondering what the "he" stood for!
