  3. how to remove duplicates in a string
  • Replies 10
  • Subscribers 150
  • Views 19276
gharish
gharish over 12 years ago
Please tell me how to remove duplicates in a given string
    You really need to provide a bit more detail. What do you mean by "duplicates"? Do you mean remove any character other than the first occurrence of that character? Do you mean remove adjacent repeated characters? Do you mean remove duplicate sequences of specified strings? Please clarify - this could mean many things, and so a clear description, ideally with examples, would help.
  • gharish
     I have a string "ABBABAAB". here elements A and B are repeteated several times. I need unique elements only.If my string is "ABBABBAB" then my output string should be "AB"
    Using the function MyUnique shown in this post, you could use:
    buildString(MyUnique(parseString("ABBABAAB" "")) "")
  • tweeks
    tweeks over 12 years ago
    This also works:
    buildString(artUnique(parseString("ABBABAAB" "")) "")
    artUnique is a private (and hence undocumented) SKILL function, so you should not use it as it is liable to be changed or even deleted without notice.
  • tweeks
    Are you sure it's private?  If it were called
    _artUnique()
    or
    artiUnique()
    then I would agree, it's obviously private, but I have found multiple (jolly useful) built-ins that appear to be public by their names, and yet remain curiously undocumented, e.g. getShellArgs(), push(), and pop().
    Sometimes an email to Cadence Support is all it takes to get them documented.  E.g., I saw to it that cons\*() and let\*() were documented.
    SKILL also appears to contain a totally undocumented implementation of Scheme-style hygienic macros, and unwindProtect()!
     Edit: unwindProtect() is documented in IC616-ISR5.
    Yes, I'm sure it's private. I wouldn't have said so otherwise. I checked in our internal registry.
    I was involved in the team that set up the rules for SKILL function naming (probably about 15 years ago now) and so most things since then follow the rules. However, certain historical functions do not - and we weren't going to edit their names (and risk destabilizing the code).
    Occasionally there are implementations in core SKILL which are not ready yet, and so we choose not to document them and make them public until they are. unwindProtect is also documented in IC615 - so that's not one. Some of the others are historically there, but have never been chosen to be made public. Depending on the state of their implementation, that may change - but I don't see artUnique being one of those because it's a utility function owned by the ADE team, and if it was public it would make more sense for it to be in core SKILL.
    The general rule is that new public functions should have a clearly public name, and should be documented. So if it is not documented, it is not public (at least not yet if it is new), and should be avoided because it is liable to change.
  • tweeks
    Thank you for the clear explanation, Andrew.
    Ironically, I found a private function for determining whether something is public:
    (In IC616-ISR5):
    _iliIsPublicFunc 'artUnique => nil
    _iliIsPublicFunc 'car => t
    _iliIsPublicFunc 'getShellArgs => nil
    _iliIsPublicFunc 'push => nil
    _iliIsPublicFunc 'pop => nil
    _iliIsPublicFunc 'techSetTechFileName => nil
    It is curious that techGetTechFileName() is public, but techSetTechFileName() isn't in IC616—
    especially since it was public in IC5141!
    > getVersion
    "@(#)$CDS: icfb.exe version 5.1.0 03/30/2009 07:18 (cicln04) $"
    > help techSetTechFileName
    Consulting cdsFinder database (may take a while) ...
    g_ID
    t_techfileName
    => t | nil
    Updates the techFile property of the specified library or cellview.
    This property is one of two that attach a library or cellview
    to a technology file.
    t
    That private function to find out whether something is private or public uses information from the registry that we dump into the installation, and the primary use is for SKILL Lint (when the "Cadence functions" checkbox is chosen in SKILL Lint) to tell you whether functions are private or public.
    There are occasions when functions are retired. They are still "public" but we choose to stop documenting them (we have a "override" in our database for this purpose). In this case, the function is obsolete, and if you call it you will get:
    *WARNING* (TECH-2000021): techSetTechFileName is obsolete.
  • tweeks
    Thank you very much for explaining what _iliIsPublicFunc() is for, and about "obsolete" functions (I had no idea Cadence ever obsolesced anything!).
    Please let me know next time you are in Southern California so I can buy you a pint and learn more SKILL secrets!
