  3. Getting value list in a Form Page
  • Views 16290
gharish
gharish over 12 years ago
I have created a tab field, and included this tab field in the form. The tab field consists of three pages. Now I want to access all the fields one by one in a single page.
Ex: I have fields A B C in the page2.
Now I want to access the three fields value into a single list.
    list(form->tabfield->page2->A->value form->tabfield->page2->B->value form->tabfield->page2->C->value)
    where form is the form handle, and the tab field is called tabfield.
  • gharish
    Sorry, I didn't expect this.Let me explain clearly
    I have created fields in page2 based upon a procedure, that tells how many fields should be created in that page.
    For Example I have fields created field_1, field_2, field_3.....so on. I didn't know in advance how many fields are there.now i want to access the values of those created fields. there are others fields also there in page2 apart from these fields.
    I hope you understood.
    This shows the importance of stating a clear question (as mentioned in the Forum Guidelines). There's no way I could have inferred what you are now saying from your original post; remember we cannot read your mind so you should put yourself in the position of somebody who hasn't seen your code...
    Anyway, there are several ways you could do this:
    1. Record on your tab page the number of such dynamically created fields that you created:
        tabField->page2->myNumberOfFields=3
      Then retrieve using:
        listOfVals=nil
        for(i 1 form->tabField->page2->myNumberOfFields
          listOfVals=tconc(listOfVals get(form->tabField->page2 concat('field_ i))->value)
        listOfVals=car(listOfVals) ; don't need the tconc structure any more
    2. Record on your tab page the list of field names you created (you can collect these names as you dynamically build them):
        tabField->page2->myListOfFields=listOfFields ; e..g list('field_1 'field_2 'field_3)
        listOfVals=foreach(mapcar fieldName tabField->page2->myListOfFields
          get(form->tabField->page2 fieldName)->value
    3. Use pattern matching on the field names to retrieve the values:
        listOfVals=foreach(mapcar fieldName pcreMatchList("^field_" form->tabField->page2->fieldList)
      Note that fieldList is a built-in property on a page (or form) with the list of fields on that page
    Almost certainly other ways, but these are reasonable. I'd probably use 1 or 2 as it gives you more freedom on naming of dynamic fields (should that matter). But it doesn't really matter too much...
