  3. limitation on number of nodes saved in OCEAN
  • Views 15028
mbchang
mbchang over 12 years ago
I used the OCEAN save command to save the node voltage as below:
  save( 'v "/ITOP/I0/INFC/net0706<0>" "/ITOP/I0/INFC/net0706<1>" ...)
Is there a limit on on many nodes I can save? In one of my tests I put about 500+ singals inside the save but none got saved after the simulation is done.
Jerry
    There's no limit, so I don't know why you have this problem. Best to contact customer support at support.cadence.com.
  • mbchang
    Andrew,
    Thanks. I found that if I break the save statement into several lines like
     save ( v' "/ITOP/I0/INFC/net0706<0>" "/ITOP/I0/INFC/net0706<1>")
    save( 'v "/ITOP/I0/INFC/net0706<2>" "/ITOP/I0/INFC/net0706<3>" )
    I won't have any issue but for a singe save statement with several hundred signals, I can't save anything. I will probably file a ticket with cadence on this.
    Jerry
