  3. netlist pin order for LVS
  • Views 19595
NcfC
NcfC over 12 years ago
I'm trying to change the order in which a circuit is netlisted for LVS but I got into problems.
 I've modified the termOrder in the CDF form accoding to the pin order I want and I've place the following line in ~/.simrc (and also in my cadence working dir):
auCdlCDFPinCntrl=t
I've also create a copy of the symbol as auCdl.
The problem is that, every time I export the CDL netlist, it shows the default pin order.
 Could some help me?
 Thanks in advance.
  • skillUser
    skillUser over 12 years ago
    You might not have the CDF pin order set for the auCdl simulation information section?  Take a look at Solution 20145004 to see if it helps.
    If not that, are you definitely using the analog CDL netlister?  Do you have CDS_Netlisting_Mode set to Analog?
    Hope this helps!
    Lawrence.
  • NcfC
    Hi, Lawrence.
    Thanks for the promptly reply.
    I don't have access to the solution you mention but, regarding the other questions, yes, I'm using the CDL netlister (btw, I'm using IC5141) and I have CDS_Netlisting_Mode set to Analog.
    Best regards,
