  3. Can I create a input field in a form that behaves like a...
  • Subscribers 150
  • Views 15928
Can I create a input field in a form that behaves like a password field?
Tshun Kiat
Tshun Kiat over 12 years ago
Dear Gurus,
Tried to Google and search in the forum on this topic but turn up nothing.
I'm trying to create a field in a form that allows user to enter a password that will be parsed to an external script.
Is there a way to make what they type in the password field to appear in asterisks on the form, e.g. ******
Please advise or recommend a better solution to handle this. Maybe there is a better way to parse credentials to external scripts in a more secure manner?
Thanks in advance.
Best regards,
TTK
    I wrote this a few years ago to try out the idea. It's not really very secure though - see the comments at the top.
    /* abExamplePasswordForm.il
    Author     A.D.Beckett
    Language   SKILL
    Date       Feb 05, 2010
    Modified
    By
    Attempt at a password field (displays * for each typed character).
    Has some problems:
    1. The typed characters do actually appear in the CDS.log file
    2. Will sort of tolerate typing in "*" but if you paste * over an existing
       displayed *, it won't work.
    3. If you click in the middle of the row of stars, and delete, it deletes off
       the end (because it doesn't know where you deleted)
    4. If you click in the middle of the row of stars, and type a character,
       it will end up storing stars after the newly typed in character.
    At the end you can access form->password->realValue to access the
    actual field.
    For normally typed in and deleted characters, should behave fine. Because
    it's in the CDS.log though, don't use for high security applications!
    Might also be worth setting hiSetFilter to stop everything being echoed
    in the CIW.
    SCCS Info: @(#) abExamplePasswordForm.il 02/05/10.16:54:54 1.1
    *    (abPasswordModifyCallback field newValue programmatic)    *
    *  The modify callback for the password field. Tries to hide   *
    * the value entered with stars. Not perfect (see notes at the  *
    *                            top).                             *
    (defun abPasswordModifyCallback (field newValue programmatic)
      (let (realValue realLen newLen formField starCount)
        ; Only trigger this if the field was changed by typing in the
        ; form
        (if programmatic
          (progn
            (setq formField (get (hiGetCurrentForm) field))
            (setq realValue (or (getq formField realValue) ""))
            (setq realLen (strlen realValue))
            (setq newLen (strlen newValue))
            ; Count how many stars there are already in the form field
            (setq starCount 0)
            (forall char (parseString newValue "")
                    (and (equal char "*") (postincrement starCount)))
            (cond
              ; If everything is still stars, but there are fewer than
              ; previously, assume the end was deleted
              ((and (equal starCount newLen)
                    (lessp newLen realLen))
               (setq realValue (substring realValue 1 newLen))
              ; If the number of stars is less than or equal to before,
              ; add on the piece after the last sequential star to the
              ; real value
              ((leqp starCount realLen)
               (setq realValue (strcat
                                 (or (substring realValue 1 starCount) "")
                                 (or (substring newValue (add1 starCount)) "")
              ; Otherwise just add on the new part on the end
              (t
                (setq realValue (strcat realValue
                                        (or (substring newValue (add1 realLen)) "")
            ; Produce a string of stars
            (setq newValue "")
            (for i 1 (strlen realValue)
                 (setq newValue (strcat "*" newValue)))
            ; Store the real value on the form field
            (putpropq formField realValue realValue)
            newValue
          t
          ) ; if
        ) ; let
      ) ; defun
    *                   (abExamplePasswordForm)                    *
    *     Create an example form which has a "password" field      *
    *                            on it.                            *
    (defun abExamplePasswordForm ()
      (let (password)
        (setq password
              (hiCreateStringField
                ?name 'password
                ?modifyCallback "abPasswordModifyCallback"
                ?prompt "Password"))
        (hiCreateAppForm
          ?name 'abPasswordForm
          ?fields (list password)
          ?callback 'abPasswordFormCB
        (hiDisplayForm abPasswordForm)
    *                   (abPasswordFormCB form)                    *
    *            Callback for the example password form            *
    (defun abPasswordFormCB (form)
      (printf "Password entered was: %L"
              (getq (getq form password) realValue)
  • Tshun Kiat
     Andrew,
    Thanks for sharing. Much appreciated.
    TTK
  • tweeks
    tweeks over 12 years ago
    Another solution would be to open an xterm running an appropriate script.
  • Tshun Kiat
     Thanks Tom!
