  3. ICFB SKILL script waiting for CDL IN to finish
  • Views 17544
Michel Arendt
Michel Arendt over 12 years ago
Hello!
I have the following script which imports a layout into ICFB and then creates some pins on that layout.
The problem: the process of importing the layout begins and then the script tries to open it and create the pins before that process actually finishes. So what actually happens is that my ICFB is trying to open a layout that doesn't yet exists...
The question: Is there a way for me to detect when the layout importing process is finished?
I'm currently looking at the wait() function, but I don't yet grasp how to correctly use that command for this purpose.
The script itself is, currently, as follows (mind the ambient variables):
libName = ddCreateLib("'$destinationLibrary'")
libName->techLibName = "'$refLibList'"
cdlinGuiDisplay(  )
cdlInGuiForm->netlistFile->value = "'$cellName'"
cdlInGuiForm->outputLib->value = "'$destinationLibrary'"
cdlInGuiForm->topCell->value = "'$cellName'"
cdlInGuiForm->refLibList->value = "'$refLibList'"
cdlInGuiForm->devMapFile->value = "'$deviceMap'"
            hiFormDone( cdlInGuiForm )
deOpenCellView("'$destinationLibrary'" "'$cellName'" "layout" "maskLayout" list(list(0 0) list(500 600)) "a")
cv = geGetWindowCellView()
tdList = setof(shape cv~>shapes shape~>objType=="label")
foreach(label tdList
lblName = label~>theLabel
net = dbCreateNet(cv lblName)
rect = dbCreateRect(cv list("M1" "pin") list(0:0 .1:.1))
labelPos = listToVector(label~>xy)
labelPos[0] = labelPos[0]-.05
labelPos[1] = labelPos[1]-.05
labelPos = vectorToList(labelPos)
dbMoveShape(rect cv list(labelPos "R0" 1))
pin = dbCreatePin(net rect lblName)
leHiSave()
exit
Thanks in advance!
Michel
  • tweeks
    tweeks over 12 years ago
    Hello Michel,
    I thought CDL-In was for importing CDL netlists?  I don't think you can use it to import a layout....
    Usually what people do is generate a streamin template file (i.e. the file you get from CIW->Import->Stream.... and clicking "save template"), and then invoke pipo via its *NIX command-line interface by doing sh("pipo...") or system("pipo...") from SKILL, which will "block" until PIPO is finished.  Then you just call dbOpenCellViewByType() to open the toplevel layout (it is not necessary to call deOpenCellView() followed by geGetWindowCellView()), process the layout(s), and then call dbSave() and dbClose().  You can check the exit status of sh() or system() to see if the streamin succeeded, or parse the PIPO.log file.
    If you're using a newer version of Virtuoso that has XStream (pipo's replacement), you can define an xstInOnCompletion() callback procedure to run asynchronously when the stream-in completes.
  • Michel Arendt
    Hello tweeks!
    Thanks for the reply and I'm sorry for the delayed response... I couldn't work on the script for a while.
    I'm currently trying your suggestion by using PIPO, but on my IC (5141) I only have the following options on PIPO:
    Usage:  pipo Translator SetupFile
    Translator = strmin,  cifin
        strmout, cifout
        strmtechgen, ciftechgen
    I assume that I shouldn't use the CIFIN for schematic importing (I'm already using it to import a layout). I'm currently attempting to use the STREAMIN option but, so far, have been unsuccessful. First I exported the schematic using the FILE > EXPORT > STREAM and configured as follows:
    streamOutKeys = list(nil
    'runDir "."
    'libName "CORE65GPSVT"
    'primaryCell "HS65_GS_IVX2"
    'viewName "cmos_sch"
    'outFile "HS65_GS_IVX2.gds"
    'scale 0.001000
    'units "micron"
    'compression "none"
    'hierDepth 32
    'convertToGeo nil
    'maxVertices 200
    'refLib nil
    'libVersion "5.0"
    'checkPolygon t
    'snapToGrid nil
    'simMosaicToArray t
    'caseSensitivity "preserve"
    'textCaseSensitivity "preserve"
    'lineToZeroPath "path"
    'convertDot "ignore"
    'rectToBox nil
    'convertPathToPoly nil
    'keepPcell nil
    'replaceBusBitChar nil
    'useParentXYforText nil
    'reportPrecision t
    'runQuiet nil
    'comprehensiveLog nil
    'ignorePcellEvalFail nil
    'translateTopDown nil
    'errFile "PIPO.LOG"
    'NOUnmappingLayerWarning nil
    'techFileChoice nil
    'pcellSuffix "DbId"
    'respectGDSIILimits nil
    'dumpPcellInfo nil
    'genListHier nil
    'cellMapTable ""
    'layerTable "/soft64/design-kits/stm/65nm-cmos065_536/DK_cmos065lpgp_7m4x0y2z_2V51V8@5.3.6/DATA/LIB/lib/cmos065/cmos065.layermap"
    'textFontTable ""
    'convertPin "geometry"
    'pinInfo 0
    'pinTextMapTable ""
    'propMapTable ""
    'propSeparator ","
    'userSkillFile ""
    'rodDir ""
    'refLibList "cmos065"
     As for importing:
     streamInKeys = list(nil
    'runDir "."
    'inFile "HS65_GS_IVX2.gds"
    'libName "TEST"
    'viewName "schematic"
    'techfileName "/home/michel.arendt/work/ascend/st065/layout/cmos065"
    'scale 0.100000
    'units "micron"
    'errFile "PIPO.LOG"
    'refLib "cmos065"
    'hierDepth 32
    'maxVertices 1024
    'checkPolygon t
    'snapToGrid nil
    'arrayToSimMosaic t
    'zeroPathToLine "lines"
    'convertNode "ignore"
    'keepPcell nil
    'skipUndefinedLPP t
    'ignoreBox nil
    'mergeUndefPurposToDrawing nil
    'reportPrecision t
    'keepStreamCells nil
    'attachTechfileOfLib ""
    'runQuiet nil
    'noWriteExistCell nil
    'appendDB nil
    'genListHier nil
    'skipDbLocking nil
    'skipPcDbGen nil
    'cellMapTable ""
    'textFontTable ""
    'restorePin 0
    'propMapTable ""
    'propSeparator ","
    'userSkillFile ""
    'rodDir ""
    'refLibOrder "cmos065"
    However, the result is somewhat problematic as you observe on the image I've attached. I'm probably missing some configuration somewhere, can you help me on this?
     Thanks in advance!
  • skillUser
    skillUser over 12 years ago
    Hi Michel,
    Stream Out/In is not intended for schematic export/import. The name "pipo" stands for Physical In, Physical Out, and it is for physical layout data.  For schematic export you could try EDIF, or you can also output plots of schematics, e.g. as a PostScript or other image format (depending on your version; the IC61x versions support more image formats).
    What are you trying to accomplish?  Your earlier post talks about CDL In but also import a layout, and then you mention importing a schematic in your more recent post...   In IC61x we have Spice In which is a more generic and configurable replacement for CDL In; if you can switch to IC615 or IC616 then you may find it easier to get good results.
    Perhaps if you can clarify exactly what you are trying to do, you may get better responses.
    Lawrence.
  • Michel Arendt
    Thanks for all of your replies. With your comments I've managed to get it working for IC5141 and my problem is now solved!
    I was indeed confused on a few things there Lawrence, but after your comment I revised the code and got it working. For further reference, here's the complete importing commands for Linux's shell (mind the environment variables):
     # Imports the cell's layout into the library
    echo '==========================================================='
    echo 'Importing Layout'
    pipo cifin $cellName'_noDFM.c2c'
    # Imports the cell's schematic into the library
    echo 'Importing Schematic and Editing the Layout'
    echo -e 'printf("DEBUG: Attempting to create the library: ")
    printf("DEBUG: Importing schematic: ")
    cdlinGuiDisplay()
    printf("DEBUG: Opening cellview (Layout): ")
    cv = dbOpenCellViewByType("'$destinationLibrary'", "'$cellName'", "layout", "maskLayout", "a")
    printf("DEBUG: Creating pins and labels on the layout: ")
    net = dbCreateNet(cv, lblName)
    rect = dbCreateRect(cv, list("M1" "pin"), list(0:0 .1:.1))
    printf("Saving Cellview: ")
    dbSave(cv)
    exit' > importSchematic.skill
    icfb -nograph -restore importSchematic.skill -log importSchematicLog.log
    A note: since we cannot save pins connectivity information on the .CIF files, we have to recreate the pins on the layout so that their connectivity is valid and can be used for DRC. So there's a piece of code there which opens the layout and recreates all pins from the label's position (the automated tool used - Astran - positions the labels on the grid and we just need to use this positioning).
    Thanks once again!
    Michel
