  3. Merge via arrays with skill?
  • Subscribers 150
  • Views 15311
blankman
blankman over 12 years ago
I'm looking to merge all via arrays in a layout to single vias, and to use the original via areas. For instance a 3x3 array of 0.26um² vias would become one via of 0.78um², centered at the center of the original via array. Is it possible to do this with skill?
  • tweeks
    tweeks over 12 years ago
    Yes, there are many ways to do this.
    The implementation details would depend on what you want the output to be; e.g.
    • OK with just a bunch of rectangles? Then you can use leLayerSize() and rodFillBBoxWithRects().
    • Do you want one logical via object (or CDB "symbolic" view)? Then you can use dbProduceOverlapInst() and lxComputeViaParams().
    • You could also group the individual vias into a figGroup,
    • or replace them with a mosaicInst!
      --tom
  • blankman
    Tom, thanks. leLayerSize() did the trick.
    Brian.
