  3. emtpy space in cellview when fit zoom
  • Subscribers 150
  • Views 18060
psill000
psill000 over 12 years ago
What I have tried
procedure(updateBBox()
    foreach(lll getEditRep()~>lpps
        if(lll~>layerName=="changedLayer" then
            foreach(shape lll~>shapes dbDeleteObject(shape))
foreach( steiner geGetWindowCellView()~>steiners
   dbDeleteObject(steiner)
Drawing and other size shape then delete shape.
What other way can I use to minimize the cellview for the correct zoom fit
  • tweeks
    tweeks over 12 years ago
    Unfortunately, I don't know of any magic bullet for this problem: you need to dig a little to find out what is pushing out the boundary.
    That said, here are some things you can try:
    geDeleteAllMarker(geGetWindowCellView())
    mapc('dbDeleteObject setof(shape geGetWindowCellView()->shapes shape->lpp == '("marker" "drawing")))
    when(fboundp('mgc_rve_delete_markers) mgc_rve_delete_markers())
    dbComputeBBox(geGetWindowCellView())
    hiRedraw()
    geRefresh()
      --tom
    I did think about writing something a bit more dedicated, but one approach would be to use the code example given in this post.
    For example, you could do:
    cv=geGetEditCellView()
    abTreeExample(cv~>shapes)
    you could also then use:
    abTreeExample(cv~>instances)
    abTreeExample(cv~>vias)
    abTreeExample(cv~>mosaics)
    abTreeExample(cv~>areaBoundaries)
    and so on - other interesting attributes to look at might be figGroups, blockages, rows, markers, guides, routes, steiners.
    The code allows you to sort the objects on the lower left x or y, or upper right x or y - so you can find the extent of each type of object.
    If I had more time I'd write something which just showed the bBox for each layer (say) and the bBox for each other kind of object, to give you more of a starting clue without necessarily showing every single object. But I don't, so I'll leave that as an exercise for the reader - or maybe the code above is sufficient for your needs.
  • psill000
    Thanks for the help and interest script.
    Looks like the problem is guides in the cellview.
    Does deleting the guideseffect anything in the layout environment, L or VXL?
    Paul
    Paul,
    I'm Not sure of the answer. Please contact customer support as more research will be needed, probably.
