  3. How to correct use - ddsFileBrowseCB & Delete Field when...
  • Views 2208
How to correct use - ddsFileBrowseCB & Delete Field when has hiCreateTabField
Charley Chen
Charley Chen over 12 years ago
 Dear All ,
In this code , if no  hiCreateTabField , it's correct , but when i use , it has 2 warning message.
;*WARNING* ddsFileBrowseCB: Invalid target string field: Field2; not found on the form
;*WARNING* hiDeleteFields: Can't find field Field4 in form Form. NO fields deleted.
How to fix the code ?
procedure( QQ()
       Field2 = hiCreateComboField(
       ?name 'Field2
       ?prompt "File Path"
       ?items list("This is a book.")
       ?value "This is a book."
       Field3 = hiCreateButton(
       ?name 'Field3
       ?buttonText "Browse"
       ?enabled t
       ?callback "ddsFileBrowseCB(hiGetCurrentForm() 'Field2)"
       Field4 = hiCreateButton(
       ?name 'Field4
       ?buttonText "Delete"
       ?enabled t
       ?callback "MyCB()"
       TabField1 = list(
list(Field2 5:00 200:30 70)
list(Field3 5:50 130:30 80) list(Field4 150:50 130:30 80)
       TabField = hiCreateTabField(
       ?name 'TabField
       ?notebookStyle nil
       ?pageScroller nil
       ?tabPlacement 'top
       ?tabs list("Hello")
       ?fields list(TabField1)
       ?value   1
       Form = hiCreateAppForm(
       ?name 'Form
       ?formTitle "Hello"
       ?fields list(list(TabField 0:0 640:150 110))
       ;?fields TabField1
       );hiCreateAppForm
       hiDisplayForm(Form 40:54)
);pro
procedure( MyCB()
    hiDeleteFields(Form
 list(
      'Field4
     );;list
    );hiDeleteFields
Thank you,
Charley
    Hi Charley,
    When you have a tab field (or a scroll region for that matter), most functions that you call which reference a field within a page of the tab field (or within a scroll region) need to be passed the page instead of the top level form - effectively the page is like a sub-form.
    So the callback for Field3 should be:
            ?callback "ddsFileBrowseCB(hiGetCurrentForm()->TabField->page1 'Field2)"
    and your MyCB() function should be:
    procedure( MyCB()
        hiDeleteFields(Form->TabField->page1
     list(
          'Field4
         );;list
        );hiDeleteFields
  • Charley Chen
    Hi Andrew ,
    Thank you for help.  After add and Browse , It shows  *WARNING*  hiSetCurrentForm: not a form.
    Is that all right ? How to avoid the warning message ?
    ==>It works.
    Thank you,
    Charley
    Charley,
    That's a known issue (CCR 1023977). It's with the callback for the ddsFileBrowseCB - it assumes that the first argument is a true form, which it isn't...
    You could contact customer support and get a duplicate CCR filed, which will increase the likelihood that will fix it sooner rather than later.
  • Charley Chen
    Andrew ,
    I got it. Thank you,
    Charley
