  3. *ERROR* (DB-320001): Unable to get the Cadence(R) Design...
  • Replies 16
  • Subscribers 153
  • Views 27357
*ERROR* (DB-320001): Unable to get the Cadence(R) Design Framework II license feature of "111".
Duy Hien
Duy Hien over 12 years ago
Hi everyone,
I am using Cadence IC615. I have used for 2 months ago. However, today when I was running Cadence, an error occured:
I closed terminal and try to log in again. But I could not access Cadence any more.
I found one guy got this problem before. www.cadence.com/.../27715.aspx
The different thing is I have used IC615 in 2 months (My server also has IC5141). Please explain what this problem is for me. Thank in advanced.
  • Danielrayray
    Danielrayray over 6 years ago in reply to Andrew Beckett
    Dear Andrew,
    Many thanks for your rapid reply. Wish you all the best in your work. You are such a kind person.
    I will go to consult with customer support. Thanks
    btw, I couldn't find CDS_LIC_FILE, LM_LICENSE_FILE, and CDS_LIC_ONLY under my file.
    Furthermore, I tried again to type "source .cshrc" in the terminal and then ran virtuoso.
    Even worse, it popped up the following message.
    ntugiee@MK_CentOS[/home/ntugiee]#ERROR (DB-320001): Failed to check out the 'Cadence(R) Design Framework II' license. Run 'lmstat -f 111' command to check the license usage status.
    Contact Cadence Customer Support for assistance.
    lmstat -f 111
    lmstat - Copyright (c) 1989-2008 Acresso Software Inc. All Rights Reserved.
    Flexible License Manager status on Tue 5/19/2020 00:22
    Error getting status: Cannot find license file. (-1,71)
    [1] + Exit 111 virtuoso
    I think I really have to go for help.
    Thanks, Andrew
    Have a nice day
    Daniel
    Andrew Beckett over 6 years ago in reply to Danielrayray
    So if you type:
    env | grep LIC
    does it output anything in the shell? It may be that you have not got any environment variables defined to tell it where the license server is. I suspect you're running a pretty ancient version, because of the date on the lmstat command (Acresso became Flexera in 2009).
  • Danielrayray
    Dear Andrew,
    Thanks for your rapid reply again. Sorry for bothering your day job. Here is the message report.
    ntugiee@MK_CentOS[/home/ntugiee]#env|grep LIC
    LM_LICENSE_FILE=/usr/cad/synopsys/license/sx_2010_license.dat
    CDS_LIC_FILE=/usr/cad/cadence/license/full_license.dat:/usr/cad/cadence/license/mmsim10_license.dat
    MGLS_LICENSE_FILE=/usr/cad/mentor/license/calibre2011_license.dat
    I can find sx_2010_license.dat and calibre2011_license.dat under the right path. However, I even couldn't find the "license" file under the /usr/cad/cadence.
    I would like to ask if I should make the directory which names license and then download that file, full_license.dat, on Cadence. Or I should download the whole package, ICADV12.3, to get that file.
    Thanks a lot.
    You truly a kind man.
    Appreciate
    Daniel
    You won't get the license file by downloading the software again - the license files are shipped separately as they are unique per customer. You need to contact your account team (or University program) to ensure you have the license file (and the license server needs to be set up too).
    Explaining all of this is beyond the scope of these forums, to be honest as I don't know anything about what products you have (or even who you are). So customer support is the right channel.
  • Danielrayray
    Dear Andrew,
    Thanks for your reply! I got it.
    I will go to seek help.
    Appreciate
    Daniel
  • Danielrayray
    Dear Andrew,
    I simply change my network connection setting of VMware from NAT(share the host's IP address) to Bridged(Connected directly to the physical network). And it solved.
    Sincerely
    Daniel
