  3. *ERROR* (DB-320001): Unable to get the Cadence(R) Design...
  • Replies 16
  • Subscribers 153
  • Views 27356
*ERROR* (DB-320001): Unable to get the Cadence(R) Design Framework II license feature of "111".
Duy Hien
Duy Hien over 12 years ago
Hi everyone,
I am using Cadence IC615. I have used for 2 months ago. However, today when I was running Cadence, an error occured:
I closed terminal and try to log in again. But I could not access Cadence any more.
I found one guy got this problem before. www.cadence.com/.../27715.aspx
The different thing is I have used IC615 in 2 months (My server also has IC5141). Please explain what this problem is for me. Thank in advanced.
    Presumably your issue is one of:
    1. The license server is no longer running
    2. You've run out of 111 licenses
    3. The licenses have expired
    4. The server isn't reachable
    5. You have $CDS_LIC_FILE or $LM_LICENSE_FILE set to the wrong place
    Possibly others...
    If you do "lmstat -f 111 -c $CDS_LIC_FILE" what does it report (in a UNIX shell)?
  • Duy Hien
    Thank so much, Andrew. You helped me one more time. The problem is my Licenses server is down. I have fixed it.
    Have a good day!
    Duy-Hien
  • mkza1002
    mkza1002 over 11 years ago
    Hi Duy,
    Kindly let me know how did you fix the license issue? I am facing the same problem but am unable to do something about it.
    Kashif Zia
  • Duy Hien
    Duy Hien over 11 years ago
    Hi Kashif Zia,
    If you use network license, check your server which hold the license. It may be turned off and causes problem.
  • Rena
    Rena over 7 years ago in reply to Andrew Beckett
    I'm facing the same issue. I've checked all the possible issues you mentioned, seems everything fine.
    I'm using the network license.
    license server is up and running.
    $CDS_LIC_FILE giving : 5280@cadence
    $LM_LICENSE_FILE giving : 1717@10.1.8.63
    lmstat -f 111 -c $CDS_LIC_FILE giving
    lmstat - Copyright (c) 1989-2011 Flexera Software, Inc. All Rights Reserved.
    Flexible License Manager status on Thu 12/20/2018 18:29
    License server status: 5280@cadence
        License file(s) on cadence: /home/cad/LMGR/license1.lic:
       cadence: license server UP (MASTER) v11.7
    Vendor daemon status (on cadence):
        cdslmd: UP v11.7
    Feature usage info:
    Users of 111:  (Total of 260 licenses issued;  Total of 2 licenses in use)
      "111" v6.16, vendor: cdslmd
      floating license
        root sysx :0.0 (v6.160) (cadence/5280 863), start Tue 12/18 16:35
        user2 sysx :0.0 (v6.160) (cadence/5280 2731), start Tue 12/18 16:05
       verplex: The desired vendor daemon is down. (-97,121)
    can you please help me to sort out this issue
    Rena
    Andrew Beckett over 7 years ago in reply to Rena
    Hi Rena,
    Which version of Virtuoso are you trying to run? What does "virtuoso -W" return at the command line?
  • Rena
    Hello Andrew,
    This is the return for "virtuoso -W".
    sub-version  IC6.1.6-64b.500.4
    Regards ,
    Rena
    Hi Rena,
    Nothing obvious jumps out in that case - it could be that somebody has restricted the access to the licenses, or it could potentially be that you're running an old version of the license daemons. I would suggest that you would be best to contact customer support to explore this in more detail.
  • Danielrayray
    Danielrayray over 6 years ago in reply to Andrew Beckett
    Dear Andrew,
    I have the same problems as he does. After changing the kernel file(.cshrc, .bashrc), and I re-run it. Then, I can't access to virtuoso anymore. (btw, I still use ICADV12.3)
    The terminal pops up the following message:
    ntugiee@MK_CentOS[/home/ntugiee]#ERROR (DB-320001): Failed to check out the 'Cadence(R) Design Framework II' license. Run 'lmstat -f 111' command to check the license usage status.
    Contact Cadence Customer Support for assistance.
    lmstat -f 111
    lmstat - Copyright (c) 1989-2015 Flexera Software LLC. All Rights Reserved.
    Flexible License Manager status on Mon 5/18/2020 22:48
    Error getting status: No SERVER lines in license file. (-13,66)
    [1] + Exit 111 virtuoso
    and I check the above issues you raise, I find the network is unreachable after I type a command," ping 8.8.8.8", to check.
    But I double-check the network cable line of my host computer, and it solidly links to my computer, which means it can link to Cadence with the right IP.
    Therefore, I would like to ask if it is the network problem contributing to can't access to virtuoso. If it is, how to solve it.
    Thanks in advance.
    Appreciate
    Daniel
    Andrew Beckett over 6 years ago in reply to Danielrayray
    What is $CDS_LIC_FILE set to? Do you have $LM_LICENSE_FILE set? What about $CDS_LIC_ONLY?
    To be honest, this is best handled by customer support so that you can get a response in a timely fashion (I'm a bit busy with the day job today).
