  3. How to display on screen text prompts?
  • Subscribers 150
  • Views 16810
girig
girig over 12 years ago
 Similar to the on-screen prompts that Toolbox commands display on the graphical layout window, is there a way to display custom text through skill? One could use labels, but then is there a way to get rid of the + (plus) sign displayed on a label text?
Giri.
    Hi Giri,
    You could use "hilight sets". For example:
    hs=geCreateHilightSet(geGetEditCellView() list("y1" "drawing"))
    geAddHilightLabel(hs 13:4 "Big Label" "centerCenter" "R0" "stick" 1.0 t)
    hs->enable=t
    You could also set the prompt in the window by doing:
    hiSetWindowDefaultPrompt(hiGetCurrentWindow() "My prompt>")
    Drawing actual labels would be a bit odd, but you can control the drawing of the label origin simply by doing:
    hiGetCurrentWindow()->textJustificationOn=nil
  • girig
     Perfect. Many thanks !!
    Thank you,
    Giri.
  • psill000
    psill000 over 12 years ago
    Sorry if this is off topic, just trying understand hilight set objects and minize trial and error.
    Are the objects valid objects in the cellview?
    Does the cell have to be open in edit to create the hilight set?
    The only way to delete the objects is with geDeleteHilightSet?
    Where can I read more about hilight sets?
    I was looking to create a object similar to ruler:
       Can be drawn in read mode
       Not saved to cellview
       Easily view to mark a position
       Without the numbers associated the ruler
    Paul
  • skillUser
    skillUser over 12 years ago
    Hi Paul,
    Hilight objects are not in the cellview database, think of them as an overlay on a cellview where the highlights can be related to cellview data or can be stand-alone highlights.  The cellview can be open in read-only mode, and in some of my testing it was quicker to create highlights than an equivalent db object (e.g. geAddHilightLabel vs. dbCreateLabel).  You can 'turn off' hilights, in other words, you don't necessarily have to delete them. The visibility of the whole hilight set can be toggled on and off, and if memory serves individual object also.  The hilight set can go away when the cellview is closed - it cannot be saved (a global hilight set can be persistent I believe).  Take a look at Solution Article 11230016 for a code example, and this documentation for an overview. It sounds like hilight sets meet your criteria.
    Hope this helps!
    Lawrence.
