  3. How to convert wtype (window type) to string?
  • Subscribers 150
  • Views 15902
DesmondLiu
DesmondLiu over 12 years ago
Hi all,
     I want to customize my filter style for LPP, first I need to know my current window so I used  hiGetCurrentWindow() but it returns wtype data, I can't use it to feed into pteSetSearchMatchType and pteSetSearchOperator functions. Could anybody help me on this? Thanks a lot.
  • Li Ting
    Li Ting over 12 years ago
    Both pte* function takes a window ID which is what hiGetCurrnetWindow() returns. So I don't see the need to convert it to a string. Also if the windowId is not given, the current window ID is assumed by these two pte* functions.
  • dmay
    dmay over 12 years ago
    Here is a command to get you the palette window regardless of the current window:
    procedure(myGetPaletteWindow()
        lswWin = car(setof(x hiGetWindowList() hiGetAppType(x)=="Palette"))
    This works when the layer palette is setup as a separate window:
    bash/ksh/sh: export CDS_PALETTE_TYPE=SingleWindow
    csh/tcsh: setenv CDS_PALETTE_TYPE SingleWindow
    Derek
    Derek,
    That's true, but unnecessary in this case (and it will only work in IC616 when you have a single separate "LSW-style" palette). These functions (in the original question) don't require the window id of the palette window, but the corresponding layout window AFAIK.
