  3. ddsSyncWithForm Question
  • Views 16157
acook
acook over 12 years ago
When I run ddsSyncWithForm, it does not block my code from proceeding. For example
procedure( myButtonCB()
 ddsSyncWithForm(myForm 'browse 'libName 'cellName 'viewName)
myfunction()
I would like myfunction to run after the user has selected a cellview, instead it exectes immediatly.
As suggested in another post, I do not want to just trigger every time myForm->viewName is changed since I cannot know that the user has chosen the cell they want yet.
Is there a way to create a dialog that where the user selects a LCV and then returns that selection and allows the code to continue to execute or do I need to write my own implementation?
Thank you,
Aaron
    Aaron,
    I don't believe there's a blocking version of this. You'd probably have to build your own.
  • acook
    I went down the buld your own path (which was a good choice actually) but now I've got a new issue.
     For some reason the callback on my listbox is taking forever (1-4 seconds) so when I select a library there is lag until the cells get shown. I did some debugging and the lag does not seem to be due to my callback.
    Here is what my listbox looks like:
       l_lib = hiCreateListBoxField(
          ?name 'l_lib
          ?prompt ""
          ?choices libList
          ?value list()
          ?defValue list()
          ?valueByPosition nil
          ?callback "CGlibSelectCBlib"
          ?changeCB ""
          ?multipleSelect nil
          ?doubleClickCB ""
          ?CBOnReselect ""
          ?keepHistory nil
          ?enabled t
          ?invisible nil
          ?help ""
    Here is it's callback:
    procedure( CGlibSelectCBlib()
       current_lib = car(cglibselect_form->l_lib->value)
       cellList = ddGetObj(current_lib)~>cells~>name
       cglibselect_form->l_cell->choices = cellList
          cglibselect_form->storedCells = cellList
       CGlibSelectCBcell()
    It takes several seconds to get to the first line in that callback. Is this normal for the listbox or something up with my code library?
    I don't think it's taking several seconds. What is happening is that the callback doesn't get called until the focus moves out of the field - that's normal with all field types. I tried this - if I move my cursor out of the form, then it gets triggered.
    I think you probably want to use ?changeCB rather than ?callback. If you do that, it calls the callback as soon as you've clicked.
  • acook
    Ahh! Sorry, I just didn't read the doc well enough.
    t_changeCB
    SKILL command executed when the value (selected items) of the
    list box has changed. Programmatic SKILL changes can also
    trigger this callback, for example:
    form->listbox->value->list( “newValue”)
