  3. changing the fileds in selection options form using ski...
  • Views 16653
changing the fileds in selection options form using skill
aru21
aru21 over 12 years ago
I am trying to change the selection form’s options(which opens when we select options->Selection on layout window) without opening the form.
I have used geHiDisplaySelectionForm() but this opens the form.
Is there some way I can do this?
    Please explain which selection options you are trying to set, then I can explain what you're asking for with an example that's relevant to you.
    Kind Regards,
  • aru21
    I wanted to change to the selection option in full mode to "Enclosed and crossed figures". so as to  select the crossed figures as well.
    thanks,
    This is controlled via a window property:
    hiGetCurrentWindow()~>fullSelectionMode="enclosedAndCrossed"
  • aru21
    it worked
    thanks,
    Arushi
