  3. Control flow when a return from a function is nil
  • Views 18072
jsaenznoval
jsaenznoval over 12 years ago
 Hi everyone,
I want to determine when the return for any function is nil using a control structure (i.e. if operator) in SKILL. I mean:
if ( return(function(a,b,...,c))=nil
 Any suggestions or solutions?
    if(!function(a b c) then ...)
    or you could use the fractionally less efficient:
    if(function(a b c)==nil then ...)
    I'm sure this is in the SKILL Language User Guide. Since everything in SKILL is a function, everything has a return value.
