  3. Create a print out log GUI
  • Replies 10
  • Views 20503
psill000
psill000 over 12 years ago
My script has some print outs and is there a way to create a print out log GUI of those print outs.
The closest thing I could find is the  hiCreateMLTextField, but I would have to append every string to the current value. Also, I dont know how clear it may become in reading previous and if the string would become too big and cause problems.
It is not that big of an issue to append the string, just looking for the most effective way to have a print out log GUI.
The print out would be strictly used for reading print output. I know I can print to the CIW, but some users want a print out GUI.
Paul
  • skillUser
    skillUser over 12 years ago
    Hi Paul,
    You could do something like the following
      msgwin = hiCreateWindow(nil "text" "Messages" "" t)
      msgwin->neverCurrentWindow = t
      hiSetViewfile(msgwin "")
      hiEnableTailViewfile(msgwin)
      hiDisplayWindow(msgwin)
    You may need to add a close function, but I think sending the messsages to a specific log file and displaying in a window that can automatically update should meet your needs.
    Lawrence.
  • skillUser
    Paul,
    You can add the (hopefully) already existing File menu as seen on a View File window:
    when(boundp('fileMenu) && hiIsMenu(fileMenu)
      hiInsertBannerMenu(msgwin fileMenu 0)
    Something like that...
    Lawrence.
  • psill000
    Is there a way to add the text without creating a file?
    Sorry for being difficult, but can I use just a *printf function to the cell window.
    Paul
    See this post.
  • psill00
    psill00 over 12 years ago
    How do indentify the window?
    I tried using hiGetWindowList()
    win=hiCreateWindow(nil "text" "Show File")
    win~>??
    window:8
    (searchWrapAround t scrollToLocation t ignoreCase
        t exactWord t
    Paul
    Paul,
    I don't understand your question. If you meant "identify" then hiCreateWindow returns the window id. If you meant "indentify" then I have no idea what that word means!
    Please clarify what the issue is.
    Kind Regards,
  • psill000
    Sorry for not clarifying better.
    I have one procedure that creates and prints to the window.
    Later I have another procedure I want to print to the window.
    How do I identify from the mutliple windows I have open on which window I can print?
    Paul
    Paul,
    Why not assign the windowId to a variable that you can then refer to later?
    If you really don't want to do that, you could always do:
    win=hiCreateWindow(...)
    win->thisIsMyWindow=t  ; or whatever you want the property to be
    and then you can find it later by doing:
    win=car(exists(winId hiGetWindowList() winId->thisIsMyWindow))
    But it seems more sensible to keep track of it rather than having to search for a property on the window.
  • psill000
    I have a few procedures that pint to the dialog box.
    If the procedures were nested I would pass the window variable, but several procedures outside of each other need to print out to the window.
    Paul
    You could just use a sensibly named global variable to hold the windowId. If you have an aversion to global variables for such things, then you could always use some lexical scoping using the SKILL++ (Scheme) features:
    let((windowId)
      globalProc(CCFcreateTextWindow(@rest args)
        windowId=apply(hiCreateWindow args)
      globalProc(CCFgetTextWindow()
        windowp(windowId) && windowId
    Then you can create a window using:
      CCFcreateTextWindow(nil "text" "Show File")
    and later refer to the ID using:
      CCFgetTextWindow()
    The file above needs to be put in a file with a ".ils" suffix. It will also only work from IC615 onwards because it uses globalProc. It could be implemented in earlier releases by doing:
    let((windowId)
      CCFcreateTextWindow=lambda((@rest args)
      CCFgetTextWindow=lambda(()
    No global variables were harmed in the implementation of this code.
