  3. SKILL Api to read sexp file
  • Subscribers 153
  • Views 16834
kb how
kb how over 12 years ago
Is there any skill API to read sexp file? Appreciate your help.
Many thanks
-Kian Boon-
    Assuming that by "sexp" you mean "s-expression", then lineread() is what you want.
  • kb how
     Yup, thats s-expression file.
    lineread will do? Let me try it out.
    Thanks a lot, Andrew.
  • kb how
    Thanks Adrew.
    It works, must i still need to post-processing the result.
    Appreciate if u have any example so i can refer? I was thinking the result will build as a list where i can directly obtain the info.
    How,
    I don't understand. You can directly obtain the info from the list. For example, if I have a file "config" which looks like this:
    (nil
      library "mylib"
      cell "mycell"
      view "layout"
      works t
      expensive "very"
    Then I do:
    port=infile("config")
    data=car(lineread(port))
    close(port)
    now I can do data->library and data->view etc. Note the car - this is needed because lineread returns a list of forms, as there could be more than one form (sexp) on each line.
