  3. How do I get the name of metal layers from the tech fil...
  • Views 16782
How do I get the name of metal layers from the tech file
Michael L
Michael L over 12 years ago
In the techParams section of my techfile, there are variables called "metal1_layer", "metal2_layer", ect, all set to the layer and pourpose pairs that show up in the LSW.
Is there a way to get the layer name from the "metal2_layer" variable in the compiled techfile?  I would like to test to see if it is set, and if it is set obtain the name.
  • skillUser
    skillUser over 12 years ago
    Hi Michael,
    Yes, if you obtain the technology file ID in the session you can access the technology parameters, here's a brief example:
    tf = techGetTechFile(geGetEditCellView())
    => db:0x170af592
    techGetParams(tf)
    => (("maskGrid" 0.005) ...
    There is also the techGetParam() function to look for a specific parameter.  Hopefully this is what you are looking for?
    Best regards,
    Lawrence.
