  3. Reqular expression in skill programmin
  • Views 15440
Vaasu
Vaasu over 12 years ago
Can anyone explain me how to use use the regular expression in skill programming........
I'm geeting many info from cadence from that I want only PMOS and  NMOS information from this command geGetEditCellView()~>instances~>cellName
Result is  ("N_18_MM" "N_18_MM" "N_18_MM" "opin" "ipin" "ipin" "ipin" "ipin" "ipin" "ipin""ipin" "P_18_MM" "P_18_MM" "P_18_MM")
From this I want only  "N_18_MM" &"P_18_MM" info
    If using IC61X, you can use:
    pat=pcreCompile("^[PN]_18") ; or "^[PN]_18_MM$" if you want to be complete
    instances=setof(inst geGetEditCellView()~>instances pcreExecute(pat inst~>cellName))
    I'm assuming you wanted the instance objects, not the names.
    In IC5141, you'd have to use the older rex functions. PCRE is the Perl Compatible Regular Expression library and has a much richer pattern matching syntax than the very basic "rex" regular expressions. For rex, you'd use:
    rexCompile("^[PN]_18")
    instances=setof(inst geGetEditCellView()~>instances rexExecute(inst~>cellName))
    In this specific case, the regular expression needed is very simple, so either would do.
    You don't even really need a regular expression:
    instances=setof(inst geGetEditCellView()~>instances member(inst~>cellName) '("P_18_MM" "N_18_MM")) )
    Best Regards,
  • tweeks
    tweeks over 12 years ago
    This approach is more complex, but also more efficient for designs with a lot of instances:
    instances =
      foreach(mapcan instHeader setof(instHeader deGetCellView()->instHeaders
                                     member(instHeader->cellName '("P_18_MM" "N_18_MM")))
          instHeader->instances
  • Vaasu
     Yea it is working thanks for your suggestion
